Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,481
   / Harbor Freight Tools that don't suck #8,482
Great advice. Thank you.
   / Harbor Freight Tools that don't suck #8,483
[portable bandsaw] Can you describe it some more? How good is the cut and how easy to handle?
I don't see that anyone responded to this point - The version HF has sold for several years is capable of a true, clean cut. It isn't very heavy so its easy to hold, and to use in awkward positions. (This should apply to the new models also).
It's one of those tools where the first time you use it you say 'I should have bought this long ago'.
   / Harbor Freight Tools that don't suck #8,484
Thanks Reb. I think I need one in the 15-25 watt range, but an all in one.
Sunforce has been around a while, not sure if they are any better. So many of these solar builders come and go...
I replied without thinking it through. What I did works great for my purposes, but it requires some math to determine whether the charger will replenish the required load for an application like yours.
   / Harbor Freight Tools that don't suck #8,485
Thanks for the replies everyone. I'm going to keep an eye out for a sale on it and give it a try.
   / Harbor Freight Tools that don't suck #8,488
I did not have trouble with the blades like he did - the blade goes inside of that screw (at least on mine). To get the blade off just required a little twist and pulling away from the housing.
Ken
   / Harbor Freight Tools that don't suck #8,489
I would naturally assume the blades would be cr@p. Even a better bandsaw or whatever seems to have questionable blades on it. Not sure why but that's my experience.
   / Harbor Freight Tools that don't suck #8,490
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
Dayton 32965 80-Gallon Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
