Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #5,651
I'll give a 4/5 star review for the HF pipe/tube notcher, model 42324. Tubing Notcher & Pipe Notcher. About $32 with coupon.
It's a copy of a US made notcher that sells for about 4x the price. Main body is 0.223" steel and sturdy enough. Base needs to be bolted to a workbench or drill press. Adjustment range from perpendicular is 0-60 degrees left. The pipe clamp hold up to 2.25" pipe. The spindle is 3/4" with 1/2"-20 threads and a 5/8" adapter is included. Worked fine with my HF Warrior bimetal hole saw set although you need a skinny 7/8" wrench to dismount the adapter once the hole saw is tightened. There isn't enough space to fit a standard thickness wrench between the mounted hole saw and the washer. I ended up using pliers.
The spindle support is machined aluminum. The machining seems true but there is more play than desirable.
I used a HF 1/2" low speed drill and it had way more power than needed to notch 16g tube. Virtually any drill press would have even more power.
I used it to notch the ends of 1 3/8" 16g fencing tube. The notches were consistently slightly off center and after examining the tool I can see that the clamp requires shimming (such a surprise with a fine quality HF device!!). Needs about a half to one millimeter shim which will be easy to insert. Otherwise the tool functioned fine. No plastic bits to break and nothing much to wear out except the aluminum block which seems beefy enough though a bit sloppy. I'd imagine the tool will last quite a number of cuts.
Overall a useful device for non critical notching though in typical HF fashion it isn't true right out of the box.
   / Harbor Freight Tools that don't suck #5,652
For those that have bikes, their motorcycle lift is awesome for the money. Get the coupon for $299 and one of their wheel chocks (the wheel clamp that comes with it is no good) for $35 and you've got a good lift for less than half it would cost from the cheapest competitor.
I'm also really happy with the bench mount drill press I got from HF.
   / Harbor Freight Tools that don't suck #5,653
The issue with the bike lift is stability when the bike is raised on the stand. I know, I have one and I use it for the zero turn to clean the deck, not the bikes. Nothing like getting a Dresser up on the stand and have it wobble. The thught of a 700 pound plus bike falling off.... and the collaterial damage to the bike or you if it falls on you, is just too much risk for me.
   / Harbor Freight Tools that don't suck #5,654
had my wife stop by HF today and pick me up a 50 foot rubber airhose on sale. I used the heck out of my last one (5 years) and it finally had a blowout after countless kinks and run overs....
She also got me a package of shop towels on sale, real cotton ones. No more cut Tee shirts as rags now.
2 more packages of wheel weights too.
   / Harbor Freight Tools that don't suck #5,655
I think he is talking about this one?
Motorcycle Lift Table, 1 Lb. Capacity
   / Harbor Freight Tools that don't suck #5,656
Could be. The roll around one (Sears sells a similar one) is very unstable, especially with a heavy bike. When I change my oil in the bikes I just use 2 nylon web slings and the overhead hoist in the shop. I can lift the bike to eye level that way, but not everyone has an air hoist in their garage.
   / Harbor Freight Tools that don't suck #5,657
The key there is to not have a 700# bike. ;) Yeah, I wouldn't feel good about that either but it works great for my bikes even at full lift....never a wobble that worried me. Of course, my bikes are all 400#s...give or take.
   / Harbor Freight Tools that don't suck #5,658
Yeah, that's the one I have. They put coupons in the bike magazines for $299. That wheel clamp you see in the picture is *****, but easily and cheaply replaced....otherwise it's great. As soon as I get my new shop built, I'll be getting a couple more. I think they have an air lift as well (just hooks to your house air), but the hydraulic one works great and goes up fast enough for me.
   / Harbor Freight Tools that don't suck #5,659
Was there a post here comparing the version 1 / version 2 180A mig welders?
(#68886 vs #62181).
   / Harbor Freight Tools that don't suck #5,660
3 day sale on these items recently mentioned.
Bruce
Auger Drill Bit (A56857)
Auger Drill Bit...
2025 Wolverine SP-15-84W 84in Snowplow Skid Steer Attachment (A55973)
2025 Wolverine...
Informational Lot - Financing (A56435)
Informational Lot...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 REMOLQUES DEL NORTE 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 REMOLQUES DEL...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
