HB580 belt slipping off
   / HB580 belt slipping off #1
Mumzly04
Ventrac
Any idea what would be causing the belt to slip off the power broom? The tensioner seems to be set fine and it’s run around 2500-3000rpm. I have no idea what would be causing this. Belt issue maybe?
   / HB580 belt slipping off #2
Well, given your belt is tensioned proper and you have the correct belt; I would first check that pesky belt guard that tends to get bent. It may be levering the belt off. If that is OK, check the sheeves for string or vines wrapped aroung their grooves. I don't think there is much chance of the idler pully being bent out of alignment. When ya figure it out, let us know. WELCOME to the fire!
prs
   / HB580 belt slipping off #3
I had a person that worked for the dealer load my tractor and never said a word but he rammed it into the front of the trailer and bent the drive pulley mount and I got it home and tore up a drive belt had to fix ir myself but they replaced the drive belt. When it's hooked up see if it looks lined up if not it's your problem.... Jim
I’m going to be breaking out the square today and checking it out and making sure the cover isn’t mangled. I’ll let you all know the outcome. Thank you all for the tips.
   / HB580 belt slipping off #6
You can eye ball it close enough to see if it is lined up when the tension is applied. Also make sure the tension is right..... Jim
   / HB580 belt slipping off #7
I reckon you got it fixed by now; what was wrong?
2015 UTILITY TRAILER MFG. CO. PUP (A58214)
2015 UTILITY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Toro Greensmaster 3150-Q Commercial Reel Mower (A56857)
2017 Toro...
JMR 48x96 Work Basket (A57149)
JMR 48x96 Work...
1999 FREIGHTLINER FLATBED (INOPERABLE) (A58214)
1999 FREIGHTLINER...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A56857)
2019 Caterpillar...
