Maryland Heavy older PTO needs U joint repairs
   #1
varmint
Veteran Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I got a PTO shaft with an older brush cutter, and I knew the shaft needed its U joints replaced, so I took out the old cross pieces. Before spending the $24 to get new cross kits, I thought to check the length, and found that with a min. 6" overlap of the inner and outer shafts, it was about 4" too short, so I had to buy a new shaft. I am hoping someone can rescue this PTO, since it's a nice heavy duty one- solid 1" sq. inner shaft. One end is 1 3/8" splined and the other 1 3/8" round. Its min. length is about 31", max. safe working length is about 39 1/2". It needs Weasler 200-1400 cross kits, or generic equivelants. I priced Ag. replacements at $11 apiece, but there are no good Ag. supply stores close by. I can ship UPS commercial rate, about 25 lbs, price to be found when I have an address, and I'd like to get $20 for it, or $15 if just picked up, here in Balto. county north of Baltimore.
   #2
PILOON
Super Star Member
North of Mtl,Que,Can (Ste Adele)
MT180D
Since the inner is actual 1 x 1 you can always easily extend it.
Any good shop can do that at reasonable $$'s.
With a 1 x 1 square shaft that's a very old one.
Newer shafts are rectangular, 3 sided or of some other keyed design.
ruffdog
Super Member
southern wisconsin
Bobcat Toolcat 5610 G series w/turfs
By the looks of the female section, it has been run mostly extended for some time.
OP
varmint
varmint
Veteran Member
Northern Maryland
Yep- but once you get into the female shaft a bit, it is fine, but whoever had it wasn't kind to his tools- the u joints hadn't been greased in who knows how long? I'm hoping someone needs a 32"-39" working length shaft?
All my other PTO's are triangular in shape.
OP
varmint
varmint
Veteran Member
Northern Maryland
Sold
