HELP! 580C ONLY GOES IN REVERSE
   / HELP! 580C ONLY GOES IN REVERSE #1
Alabastershame
Case 580c
Recently purchased a 1981 case 580c. It had no forward when I bought it. Tried cleaning the screen and changing the fluid, kind of seemed like it had been tried already. Goes into reverse without hesitation.
   / HELP! 580C ONLY GOES IN REVERSE #2
Check for wear in the linkage if shifter or pedal rocker. If hydraulic valves, check control pressures. Could be a worn valve. I'd be looking for a shop manual if you plan to do the work yourself. Typical user manuals will be worthless.
197637 (A50459)
197637 (A50459)
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
