Oil & Fuel HELP. Oil change on MT 372D
   / HELP. Oil change on MT 372D #1
rzacc
Greetings all. I have a really dumb question. Just bought a well used MT 372D. Where is the oil fill spout? How do I add oil to it? I assume there is not dip stick but I cant find the sight hole either. Can someone help?
ALso, can someone tell me if new glow plugs might be available for this tractor? It just will not start when it's cold.
Thanks in advance.
R
   / HELP. Oil change on MT 372D #2
The oil filler is on the right side of the engine. Low near the bell housing. Clean any debris away from the cap before you take it off. It is threaded on and has a little tab to grab to twist it off. The dip stick is likely attached to the inside of the cap.
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2023 Ford Explorer SUV (A48082)
2023 Ford Explorer...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
