Hiptfarms
- Joined
- May 23, 2013
- Messages
- 303
- Location
- Fairfield County, SC
- Tractor
- Kubota M6800 with BH FEL, Kubota L4400 HST with FEL, Polaris Ranger, BCS 720
I picked up an abused 720 last year and am finally getting around to working on it. The clutch is seized and the engine is toast so I picked up a cheap Predator engine to put on it. Today I pulled the old Briggs I/C 7 hp off along with the clutch. The problem is I cant seem to get the allen screw loose so I can slide the cone clutch off. The set nut loosened fine but for the life of me I cannot get the Allen screw to budge. I've tried spraying silicone spray on it and nothing. I tried a small amount of heat and still nothing. ( I was scared to put too much heat on it). Now I'm letting some automatic transmission fluid set on the it in an attempt to let it loosen.
Any suggestions?
Any suggestions?
