Help! Sucked up 100' hose in tiller
   / Help! Sucked up 100' hose in tiller #11
Torch and 2 beverages?
:stirthepot:
Regards, Fred
   / Help! Sucked up 100' hose in tiller #13
Leave it tied to the tree and put er in reverse.:eek::p
   / Help! Sucked up 100' hose in tiller #14
I know how you feel I do a lot of beach tilling and find a lot of stuff buried ski or anchor ropes garden hoses but the worst is romex wire. Raise tiller and disconnect pto shaft then tiller will turn backwards helping to unravel have a bed frame in rotary mower now that will take torch to get out ain't it fun.
   / Help! Sucked up 100' hose in tiller #15
I've used a sawzall before. I borrow my boss' tiller for the tractor and it always clogged when I get it. Since its normally delivered in the back of my truck and I have to lift it out with the loader, I sit it on the edge of my deckover trailer (good working hight) and block it up safely. Then a sawzall with a long blade makes quick work of most of the trash he leaves wound up in there, but good wire cutters and a sharp utl knife are always on hand as well.
Good luck...
   / Help! Sucked up 100' hose in tiller #16
Electric fence wire is worse . So is rope. You can tell yourself you will never do that again but you will, I will and everyone else will . File it under chit happens in the Twilight Zone. :confused3:
   / Help! Sucked up 100' hose in tiller #17
Pressure wash it to get the mud off, then cut the hose out with a razor knife.
Not a fun job at all (but not as bad as mattress in a bushhog).
Aaron Z
   / Help! Sucked up 100' hose in tiller #18
Aaron Z
How about a 10.00 x 20 tire halfway thru a flail mower used on right of way
   / Help! Sucked up 100' hose in tiller #20
Go back and look at the tool I made in my post--#4. It works like a dream and I get stuff wound up all the time from commercial tilling.
A tool like this allows you to flip the back lid up, lift the implement and sit on the ground to use pulling stokes to cut loose whatever ails you. I could cut that hose off in maybe 5 minutes and long before the brew was either warm or gone...whichever comes first.
I actually got this hooked knife thing from one of those make your own knife ads in a magazine. I cut a slot in an old wood maul handle and mounted the blade with a slight back sweep to make it easier to use. Keep it sharp and I can cut off the nastiest grass wads in mere seconds.
Before the tool, tilling was always a hassle of unwinding things. Now, problems are an afterthought.
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
Polaris Ranger (A56859)
Polaris Ranger...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A58018)
2007 CHEVROLET...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
