Help with a JD serial #
   / Help with a JD serial # #11
When I received my 2210 there was a print out with the manuals. At the top is says "Stocker Tractor Build Tag" it gives the RLP Date: 02Jun2004, serial number,exp whs date:04Jun2004, and some other info. Don't know if I was suppose to get this paper or not. Ok I give, what does RLP stand for?
Ron and Cowboydoc, your discussion has helped me understand the situation better. I suppose my friend's comment about "Georgia tractors" that I referred to earlier coupled with the uncooperative dealer in Dixie, GA. caused my skepticism. I have come to the conclusion that for me a new 5303 with a fel would be my best route. I say this because I don't think I need the "bells and whistles" and I have always used a non-synchrous tractor. Main use is to put out round rolls of hay. The used 5320 was about a toss-up in terms of $s with a new 5303. Doc you have given the 5303 good marks in the past. Do you and Ron still feel the same? Thanks again.
TK
   / Help with a JD serial # #13
My local JD dealer gets in a lot of what he calls Peanut tractors. They are used for hauling peanut wagons from the field to the processor/collection point. Normally 100-300 hrs. They look new except the drawbar is worn. Most are 2wd but some are 4wd, all 5000 series.
Jeff T.,
The tractor I was interested in may have been used for a "peanut" tractor or something similar. I thought it was a little unusual that it had no hydraulic remotes. That would explain that. I didn't get far enough along in the deal to drive 5 hrs. to see the tractor. Might have seen abnormal drawbar wear if I had. Thanks.
TK
   / Help with a JD serial # #15
I would not call it abnormal wear, just the only wear noted on most is some paint off the drawbar.
UNUSED 400PCS 39 in. Zip Ties (A50860)
UNUSED 400PCS 39...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A48082)
2009 Skeeter SL190...
3-Point Disc Plow (A50860)
3-Point Disc Plow...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
Anvil (A50860)
Anvil (A50860)
Auger (A50860)
Auger (A50860)
