Help with non working gauges
   / Help with non working gauges #1
jeephound1
Tyler, Tx
2009 cub cadet ex3200
I'm new to the forum, so hope I get this correct.
I just purchased a 2009 Cub Cadet Yanmar EX3200 tractor and my fuel gauge and Temp gauge are dead. All warning lights, tach, hour meter, headlights and dash lights work perfect. Any help or ideas? Thank you
Thanks, I did check all fuses and they're good. Each gauge has 3 wires on back of them, red, black, yellow. With a test light bought gauges red wire has power.
   / Help with non working gauges #4
I'm sure you have probably checked the sensors making sure the wires are connected to them?
yes sir, even tried grounding the positive wire on the fuel sending unit. Nothing happened with the needle on the gauge. I haven't pulled the sending unit from the tank.
   / Help with non working gauges #6
Do you have a wiring diagram? I am wondering if one of the 3 wires going to the gauges is for illumination?
I bet the yellow one is lights, I'll check it.
   / Help with non working gauges #8
I would guess yellow is ground, black and red hot. Sure nuff a guess.
Fuel gauge worked a couple days off and on, but not the temp. Could it be a ground?
   / Help with non working gauges #10
Short answer, but yes it could be ground.
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
LOT: Assorted Vise Grips (A59076)
LOT: Assorted Vise...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A58018)
2007 CHEVROLET...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
