Help with overrunning clutch assembly
   / Help with overrunning clutch assembly #11
You could take a die grinder and rework the areas that the pawls contact if you didn't want to spend the $$$$$ E57134 Clutch ADD 163.81 Used hay cutters are a very tricky investment at best.
I think I will try the die grinder first and see if that squares it up.
That's an under statement, working on the disc part right now, drained the oil in the cutter bar and it was milky white (I suspect water got into it) plus looks like they were welding parts of the discs (possibly to fix holes) but covered the part that the socket goes into to put the knives on so I couldn't check for torque, might try and grind away some of the welding to see if I can open it back up.
2019 Ford Fusion Sedan (A48082)
2019 Ford Fusion...
John Deere 2640A Tractor (A50860)
John Deere 2640A...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2015 Club Car Precedent Electric Golf Cart (A50860)
2015 Club Car...
