SandburRanch
Veteran Member
- Joined
- Oct 12, 2010
- Messages
- 1,543
- Tractor
- NHtd75
Got tired of holding that red button down while pushing green striker button and attempting to look in that little window down below to see if / when the pilot lights. Quick Grip clamp to the rescue.
Quick & Easy - I use a small self lighting propane torch. It quickly heats the thermocouple then in a few seconds, just turn the valve to ON.
Thanks kenmac. I wish I knew the part number. Tank was purchased from a plumbing supplier so maybe someone there can locate an assembly if I give them the tank Mod. No.Can't use a torch on that type wh. It is sealed system. If your having problems with the pilot going out on that AO smith. You need to order a t.couple assy
