Hot weather shut down
   / Hot weather shut down #1
Flyfishing
John Deere x 530
I have a six year old John Deere x530 that will shut down after mowing for 30 or so minutes. It only seems to do it in hot humid weather. When it does shut down and engine stops completely it will backfire after about 1 second. After sitting for 10 or 15 minutes it will start again. Never have problems in cooler weather. Any ideas?
   / Hot weather shut down #2
It is possible the cap on your fuel tank isn't venting properly. Next time it stalls you can try removing and replacing the cap and see if it will restart without the wait. You could also check the cap for blockage to see if there's an air path through it.
   / Hot weather shut down #3
Sounds like vapor lock. A new fuel pump could be a solution, at least it solved my issue with the same symptoms.
   / Hot weather shut down #4
If you find an answer please post it here. Mine is doing that issue this year.
   / Hot weather shut down #6
One test you could do: right when it stalls, pull a spark plug out, and plug it back into the plug wire. Crank engine - is there a spark?
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
2010 Nissan Altima Sedan (A46684)
2010 Nissan Altima...
2013 JLG 860SJ 86ft Telescopic Boom Lift (A46683)
2013 JLG 860SJ...
2022 John Deere 5100M Tractor (A47371)
2022 John Deere...
2 Kubota 8.3x16 tractor tires and rims. Good tires (A47371)
2 Kubota 8.3x16...
24ft Corral Panels w/ a 10ft Gate (A49251)
24ft Corral Panels...
