How do i transport my tractor??? Help!!
   / How do i transport my tractor??? Help!! #11
yep.. pull lines iff needed, lift arms, clamp some angle tot he puiston,
heck.. put a hot battery in it and use the starter to load on the trailer.. :) as long as it is not an sos, or has drivetrain issues. BTDT easier than a winch...
soundguy
   / How do i transport my tractor??? Help!! #12
^^ good advice. A couple of split pipes and some hose clamps would keep that loader up until you get it where you want it. :thumbsup:
Yep! Every FEL should have one (or more of different lengths for different situations) to provide a positive stop for the loader arms. Just be aware that you have to be careful the pipe ends don't push against the end wiper seals or they will be damaged. The oil seals are deeper in and are safe but those wiper seals aren't.
   / How do i transport my tractor??? Help!! #13
that's why I like angle iron. the profile usually lets it rest against the gland nut instead of the wipe.
soundguy
   / How do i transport my tractor??? Help!! #14
Note to self.....remember above advice. Good post. :)
   / How do i transport my tractor??? Help!! #15
soundguy
I also use angle iron tied to the rod when working under the loader. In fact, the dealer gave me the piece of angle iron they used on one of Old Stoney's trips to the ER.
If I were going to transport it that way, or with split pipe, I'd put something (rags, oil blanket, inner tube rubber, etc.) between the iron and the rod to keep the vibration and bounce fom scratching the chrome.
Good luck, Wm
PS Here's an opening to show y'all this one:
YouTube - loading non-runner.m2ts
   / How do i transport my tractor??? Help!! #16
I don't think I'd transport it with the laoder up. I'd drop it, then re-jigger it up for unload. dot really likes for implements to be on the deck and not suspended.. loaders included.
I know it would be 'transport locked'.. but why take the risk.
soundguy
thanks for the advice guys. with my lack of knowledge regarding tractors and implements im gonna take the safe route and get somebody to tow it for me. Its not going to cost me that much and ill have peace of mind knowing itll make it safe! thanks for all the comments and suggestions!!!:thumbsup:
   / How do i transport my tractor??? Help!! #18
Maybe AAA will pick it up.:laughing:
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
POLY TOTE W/ WIRE CAGE & PALLET (A52708)
POLY TOTE W/ WIRE...
2005 CATERPILLAR 906 WHEEL LOADER (A52709)
2005 CATERPILLAR...
453 Detroit Diesel Engine (A59213)
453 Detroit Diesel...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
