How many acres do you own/operate on?
   / How many acres do you own/operate on? #31
Property?
We have a 3 BR apartment in the city with an off road parking spot. The neighbors snickered when we bought a red GC2310TLB, but they won't be laughing this winter when our parking spot is always kept nice and clear and they are out shoveling for hours.
:rolleyes:
Where do you run the Massey in the city? Looks like this was a good thread.
   / How many acres do you own/operate on? #33
Busted.
We live in the country and have a small house with < 2 acres. But after reading about all the others with their hundreds of acres and big tractors, I was feeling a bit sheepish. :eek: :rolleyes:
   / How many acres do you own/operate on? #34
30 acres, about 20 wooded, 9.5 open, 2 ponds with about .5 acre of water, with a 5103 to keep it somewhat in decent shape. Never have enough time to get it all done.
   / How many acres do you own/operate on? #35
dieselram said:
Figured I would start a little questionare here, how many acres do you use your tractor on and how big of a machine do you have? I have 25.5 of some field and woods and a 4300 TLB, 513 JD hog, International 5" box scraper and a 6' KK York rake. WANT A LARGE FRAME COMPACT!
10 acres flat pasture land. Used to have a 2005 Kubota B7510HST (21 hp engine, 17 hp pto, 4WD) with the LA302 FEL (4 ft bucket). Traded that for a new Mahindra 5525 (55 hp engine, 45 hp pto, 2WD) with the ML250 FEL (6 ft bucket).
Also have a 1964 MF-135 diesel (45 hp engine, 37 hp pto).
Going to put a hay crop on 7 acres. The 5525 is the tillage tractor that pulls 2-14 plows (either a JD 415 3pt rig or an IH #8 Little Genius pull plow),
7 ft offset disc, 7 ft tandem disc
and a MF-124 square baler.
The MF-135 handles the planting with an old Minneapolis Moline P3-6 grain drill with grass box (10 ft wide, 20 drops),
a 10-ft cultipacker
an old Allis Chalmers 80T trailer sicklebar mower,
and a JD 350 side delivery rake.
As you can see, I have zero brand loyalty. I buy what's cheap and available and fix it if I have to in order to get it to work.
   / How many acres do you own/operate on? #36
1.5 acres in MN and a whole lot of sidewalk to maintain via snowblower in the winter.
Scott
   / How many acres do you own/operate on? #37
2.1 acres in the Indy area - all grass/turf except for about 1/3 acre which
was a run-off area for water. Been reclaiming it - it has about 8"
of rich, black top soil with a hard clay base underneath.
The 3520 e-Hydro with 300CX loader, 655 tiller, ballast box, and 72" MMM does
hauling; snow removal, cutting of big weeds in the wet area. The
D928 Grasshopper does the lawn cutting and most of the snow removal
using the rotary broom.
Overkill - oh yeah! But, the 3520 has reclaimed about 1/2
acre of land; helped neighbors with tree planting, clearing, etc.
I wish the 72"MMM did NOT leave big ruts from the front casters
digging in on turns.
With all of the rain lately, my nicely turfed 1/3 acre is now
all brown and the weeds are coming back...need to find a grass
that will survive being underwater for a few to several days
after the big rains. The bluegrass, fescue blend didn't work out.
Been thinking about trading the Grasshopper for a Deere 997 ZTR,
but love the rotary broom for snow. Easy-on, easy-off.
Cheers!
   / How many acres do you own/operate on? #39
20 acres at home. 11 with hardwoods, 8 acres of wild grass, and 1 acre of lawn.
23 acres retirement property (8 years away). 18 acres of 30' high worthless red pines and 5 acres of very mature hardwoods (mostly sugar maples).
JD3520 tractor (see signature).
   / How many acres do you own/operate on? #40
33 acres in northeast Ohio. Most of it wooded (about 26 acres) with a 1400' drive. I use the 3510h to keep the field mowed and the drive cleared and maintained.
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
