How much vehicle to tow Deere 410C Backhoe
   / How much vehicle to tow Deere 410C Backhoe #71
1 tons have come a long ways in the last 20 years, or even the last 10 years. The drum brakes have given way discs, given way to big discs. The discs on a new F350 dwarf the ones on my 2001 F350, and are bigger than those on the old F-superduties.
Re: electric brakes when towing big, you shouldn't be towing big with a junk controller. The decent controllers monitor the braking circuit and alert you them being unplugged, bad ground, bad wiring, etc at which point you pull over and fix the problem or limp to a garage. You wouldn't run with a broken air valve, or leaky or broken air lines on your semi so why should you run bad controler and wiring on an electric brake rig.
   / How much vehicle to tow Deere 410C Backhoe #72
I keep imagining leaving repair notes for my imaginary mechanic, but nothing seems to get repaired.:confused:
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
COLE 1R PLANTER (A52708)
COLE 1R PLANTER...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
