How much would a good gasoline motor cost compared to a diesel?
   / How much would a good gasoline motor cost compared to a diesel?
Our Impala's max torque occurs at 5300rpm.
You’d have to have the engine with a diesel like power band. Having to re design the equipment for a higher RPM engine would take away whatever cost advantage they might have had.
   / How much would a good gasoline motor cost compared to a diesel? #32
Don't dismiss STEAM power!
   / How much would a good gasoline motor cost compared to a diesel? #33
Yes! With steam power I only need water I can collect from the downspouts and the same fuel I use for the house...FIREWOOD! The heater adjustment is how close you sit next to the firebox.
Those old steam tractors produce enormous heat. I can’t imagine having to work one of those in the summer.
   / How much would a good gasoline motor cost compared to a diesel? #35
Well, different engines that can run on biofuel in the simplest form might become popular again.
   / How much would a good gasoline motor cost compared to a diesel? #36
But it's DRY heat! lol Actually, the Radiator in my non A/C Kubota cab is inside the cab, and I figured (espcially since I HATE heat) that it would be unbearable in the summer, but it's not. On the flipside, the doors hardly get closed in the winter. Only if a wind is coming through, and then sometimes only one.
I was serious about the merits of steam. You enjoy the electricity you have, mostly by virtue of Steam.
I call those green houses on wheels. I’d never buy a cab machine without ac.
   / How much would a good gasoline motor cost compared to a diesel? #38
I have my trusty bus driver fan! lol In and out of AC on a hot day, can make you very sick! Fine, if you are staying in the cab.
2017 Ditch Witch FX50 T22S Towable Vacuum Excavator (A55973)
2017 Ditch Witch...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A56435)
2003 International...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
