how to bleed fuel lines
   / how to bleed fuel lines #1
TrueCountry
I have a 3525, I just changed the fuel filter and the tractor will not crank. Someone said to bleed the fuel line because I got air in it when I changed it and that will make it not crank. Can someone here tell me how to bleed the fuel line. Any help would be great, I dont want to have to put it in the shop. I cant afford it. Thanks
   / how to bleed fuel lines #2
You need to back off the injectors while cranking it over. When it is nothing but a constant stream of fuel (no air) tighten them back up. When they are all tight crank it again and it should start ;)
Thanks, thats what I thought...I just didnt want to mess anything up.
   / how to bleed fuel lines #4
TrueCountry,
The spin, crack, & bleed method will work with a little time & patience. On your tractor, there is a more simple method. With the fuel flow established, unscrew the hand primer plunger and simply pump the primer until you feel it getting more firm (you may even hear fuel flowing back into the fuel tank through the return line). At this point push the primer back down one last time and screw it back in place. Should be ready to run. Hope this helps.
Scott @ Artec
   / how to bleed fuel lines #5
Be sure the fuel filter is full. On some diesels, it's pretty big and takes a very long time to fill up again. Then loosen the injector lines until you get a steady amout of fuel coming out of the lines without any bubbles.
Eddie
   / how to bleed fuel lines #6
True,
Bleed the air out of the fuel filter with the bleeder on top of the canister or at the injection pump. This is just a gravity operation. When fuel shows up re-tighten the bolt. Next crack the fuel injection nuts on the fuel lines. Open them about 1/3 turn. Push the throttle to full and crank the engine. The fuel will not run steady, it will pulse. Crank for a bit and look for fuel instead of air. Then re-tighten the injector line nuts, start it and reduce the throttle setting.
You said it would not "crank" This means it will not turn because of a dead battery or bad starter. I think you meant it would turn but not start.
Some guys pour fuel into the spin on filter before installing it, but that might not be the best way because of possible contamination. I've also seen guys pour in transmission fluid when they didn't have diesel available.
   / how to bleed fuel lines #7
So, can air be bled from the system with this bleeder? I have a 3510, ran it out of fuel today, now it won't start (and the fuel filter is 1/2 empty).
The manual I have says to open the cock on the fuel pump, start the engine and let it run a while, then close the fuel pump cock. I didn't try that yet (it was almost dark when it ran out of fuel, I'm going to look at it tomorrow), but it sounds too easy...simply opening the fuel pump cock will enable the engine to start? :confused2:
- djb
   / how to bleed fuel lines #10
Yup, it sure does. :thumbsup:
Tractor will run now, but the fuel filter didn't fill up. Will that be a prollem?
- djb
Loosen the sight bowl nut and let the air out and the fuel fill it, then tighten the bowl nut back up.
2001 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2001 KENWORTH T800...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
