How to Determine PTO RPM's ?
   / How to Determine PTO RPM's ? #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
How to Determine PTO RPM\'s ?
Hello All !
I have a B2150 and an Allied/Buhler snowthrower. It's designed to run at 540 RPM's. But How do I know when I hit that RPM speed on the rear PTO ?
What RPM's should the tractor engine be turning to hit this PTO speed ?
Thanks. Tim
   / How to Determine PTO RPM's ? #2
Re: How to Determine PTO RPM\'s ?
I am not fimilar with a B2150.
Does tractor have a Tachometer? If it does, there should be a line around 2000 to 2800 rpms that indicates PTO 540 RPM's.
   / How to Determine PTO RPM's ? #3
Yes it has a mark on the tachometer for 540 Ron. /forums/images/graemlins/grin.gif
Hmmmm....
Well don't I feel stupid !
When I get home today, I'll have to take a closer look.
Never noticed, but then again, never really looked !
Thanks !
Tim
   / How to Determine PTO RPM's ? #5
Remember, the only stupid question is the question not asked. Or as my old man used to say, "There are no stupid questions, but there are a **** of alot of stupid answers." /forums/images/graemlins/tongue.gif
   / How to Determine PTO RPM's ? #6
Well here is a good answer -> our Kubota L-3130 has a live PTO rpm tachometer specifically monitoring the PTO rpms from 0-540 rpms in real-time, not some spot on the engine RPM tachometer where the PTO should be running at 540rpms.
   / How to Determine PTO RPM's ? #7
There may just be a line.. or it could say 540 or 538.. or could have a graphic of a small gear spinning.
Soundguy
When I got home last night, I went over to the orange beast and looked at the dash.
YUP ! Sure enough, there "IS" a line at about 2500 RPM that says "PTO 540". I've had the tractor for almost 7 years and never really paid attention.
Thanks again....
Tim
Now... as a follow up question.
Can I run the engine at a "Higher" RPM and exceed the PTO RPM's of 540 without damaging my snowthrower?
I was running it at about 2800-3000 since it would throw the snow farther at the higher speed.
I really don't "think" it would hurt it, but would like some input from more educated operators.
Thanks, Tim
   / How to Determine PTO RPM's ? #10
<font color="blue">
</font>
TimP, you've had the tractor for 7 years, and you've been running the snowblower at 2800rpm, which is something over the 540 PTO rpm all this time. I think you answered your own question.
But consider the gearing. It takes 2500 engine RPM to get the PTO to run at 540, so there is ROUGHLY a 5 to 1 gear down. Running at 3000 engine RPM is going to put the PTO RPM at roughly 600? I suspect there is enough safetly factor engineered into the gear box of the snowblower to handle that.
John Deere Kivel Bucket (A49251)
John Deere Kivel...
Farmall 656 2WD Tractor (A49251)
Farmall 656 2WD...
AGT MY50R Mini Excavator (A49251)
AGT MY50R Mini...
2012 BMW 528i AWD Sedan (A46684)
2012 BMW 528i AWD...
19.5L-24 Backhoe Tires (pair) (A49251)
19.5L-24 Backhoe...
25ft Extra Heavy Duty Booster Cable (A46684)
25ft Extra Heavy...
