How to fasten a 100 gal. fuel tank in the bed?
   / How to fasten a 100 gal. fuel tank in the bed? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I'm thinking of getting a fuel tank (like the transfer-tank at TSC to put in the back of my F350 to transfer diesel fuel to my larger tank (IBC tote) at the retirement house. But I don't want more holes in my truck bed. And I don't want it welded either, I want it easily removable but safe. I only plan on using it for a 16 mile trip from the local diesel supplier.
I HAD planned on just using a spare IBC tote and driving carefully. However just last week I saw an F250 w/ an IBC tote full of liquid fertilizer make a circle at the end of our suburban court. Darn near on two wheels because of the slosh in the tight turn.
I don't need the pucker factor :)
Any recommendations for "fastening" it down?
I was thinking of bolting it to a 3/4" sheet of PT plywood cut to fit the front of the bed.
   / How to fasten a 100 gal. fuel tank in the bed? #2
How is a 30 pound sheet of plywood going to hold down 700 pounds of diesel plus whatever the tank weighs? I do not understand
If it were me, I would follow the tank Mfg's guidelines but I don't mind putting holes in my truckbed.
   / How to fasten a 100 gal. fuel tank in the bed? #3
If it was a just filling it up driving home to empty it use 2 straps should be fine. I carry a L shaped tank on the front of my trailer and just use 2" straps and it has never moved.
   / How to fasten a 100 gal. fuel tank in the bed? #4
Can you go diagonally from corner to corner to the tie downs in the box over the top of the tank....Mike
The plywood CUT TO FIT the front of the bed would prevent the tank bolted to it from sliding around or tipping.
A couple of straps would enhance that.
   / How to fasten a 100 gal. fuel tank in the bed? #6
Strap it down.
Chris
   / How to fasten a 100 gal. fuel tank in the bed? #7
It would be a lot cheaper to use 55 gallon barrels and build a frame to keep them from moving. Might even go to 3 barrels for more capacity.
I have a frame that I use for my welding gas bottles that keeps them from rolling around. I have a 70 mile round trip to get filled.
That tank is steel and will rust over time and is going to be hard to move even when empty.
   / How to fasten a 100 gal. fuel tank in the bed? #9
Sorry if I offended you by my safety question. That was not my intent.
The center of gravity of the load will be well above the plywood. Cut -to-fit or not, I don't think it will keep it from tipping. The straps, opposed and above the CG will keep the tank from moving if you are careful.
Of course, I was assuming a rectangular tank. The "L" shaped tanks lower the CG so you probably would never have a problem.
   / How to fasten a 100 gal. fuel tank in the bed? #10
I agree the IBC tote would be a bad idea. First you couldn't fill it full without needing a DOT placard and CDL license. That would mean 119 gallons (or less) in a 275 gallon tank. The sloshing around would suck. Plus I think the tote would need to be DOT approved for diesel fuel.
The plywood would work fine but I would use a strap as well. Ideally it would be nice to have a couple of loops for the straps. Maybe if you could take a piece of flat steel and bend it so it gets bolted to the fuel tank and plywood and goes up one side, across the top, and down the other with rings welded to it. That would make it easy to strap down.
gravely riding mower (A55758)
gravely riding...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2016 Ram 5500 Chassis Truck (A55973)
2016 Ram 5500...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
