How to follow water pipe?
   / How to follow water pipe? #141
The divining method of backing up until you get stuck in in mud seems much more scientific.
   / How to follow water pipe? #142
There are PVC locators, but it is not based on wishful thinking. They use something called a thumper or knocker to send pulses through the PVC pipe and use a sensitive microphone to pick up the pulses. They say the range could be as great as 1000 ft.
http://www.rjmcompany.com/Plastic-Pipe-Locator.htm
   / How to follow water pipe? #144
James Randi started offering a prize for any proven demonstration of the paranormal in 1964, the prize is now a million dollars:
Challenge Info
And he says the most common applicants for the prize are for dowsing:
Library, The Matter of Dowsing
   / How to follow water pipe? #145
Challenge Info
Uggh...the Randi group has already been discussed....here's my thoughts.
I don't know if it's splitting hairs or not, but I think there's a difference between dowsing for water and locating under ground items, and in previous posts discussed that.
   / How to follow water pipe? #146
The Randi challenge is a joke anyway. No matter what an applicant does, he will insist they cheated, (and will probably be right), and then refuse to pay on that basis.
   / How to follow water pipe? #147
How do you cheat, it's either there or not there.
To those that believe in the principle, why are there no test to prove it works every time.
None of this I think it works crap. I saw someone do it one time. I did it once, with a special stick. Granny could do it, but she would not take money. It has to be a fresh peach Y branch. Welding rod is the proven choice, etc.
Before metal, what did they use, a feeling?
There is life, and there is death, and those are proven facts.
   / How to follow water pipe? #148
Sorry, I was not necessarily referring to using divining for the Randi challenge.
Divining apparently does not work every time. But then, neither does any other locating device.
   / How to follow water pipe? #149
hmm.. I say dig out the ground penetrating radar.. or a ultrasound or a 12ga sonar device.. :)
soundguy
   / How to follow water pipe? #150
Was shown how to do this when young with a couple of L bent coat hangars. Only used it while passing over a large nail or metal object. Haven't done it in years. Never tried to find any water lines with it. May have to try it and see if it will work over a cold beer...:cool:
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
CATERPILLAR 299D3 SKID STEER (A52709)
CATERPILLAR 299D3...
2002 Frieghtliner Pressure Digger (A55973)
2002 Frieghtliner...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Pick up bed (A55973)
2017 John Deere 6120E (A53317)
2017 John Deere...
