Bullwinkle123
Platinum Member
I want to get under my rotary cutter and file/shape my blades a bit after some heavy work cutting rocks (apparently).
So here I am faced with this 700+ lb 6' cutter. What's a *safe* way to get at those blades?
As I see it I have these options:
1. Hoist it up and rest it on <how many?> jack stands.
That leaves me with questions of how much height I'd need to move around under it, and how safe it would be filing away at blades when they're on a stand.
2. Hoist it with my FEL and a chain, wheel-end up in the air, flat-ish front piece on the floor.
That leaves me with questions of practicality too. Assuming I face the blades outward from the tractor so that I don't need to stand under the loader while servicing it (which I won't do), it seems like it would require a little hoist-time maneuver to pivot the cutter if the loader/chain can't pragmatically lift it from side opposite the wheel. I.e. if I lift the wheel end up with the loader right over the wheel, the cutter blades will want to face the tractor.
3. Maybe use pallet forks. But if I come from the straight edge of the cutter they'll be pressing on blades in all likelihood, and if I lift from the skirt it's unlikely to be as stable as jack stands, and far more likely to slip, I would think. So I'm not really considering it forks a viable option.
What do you experienced folks do to get under your cutter?
