prof fate
Platinum Member
- Joined
- May 30, 2018
- Messages
- 684
- Location
- beaver pa
- Tractor
- kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
From what I've been able to find I can spray 2,4-D and kill the offending weeds.
HOW to spray is my question.
I have a spot sprayer...but no spray bar. I can build one (seen several videos from people that have done it).
The bottle says something like 2 quarts per acre....how on earth do you figure out how to do that?
I've only ever spot sprayed roundup, like on a fence line, driveway, etc - get the leaves wet and move on. I mix at 3oz per gallon and just go spray.
I assume you catch the flow and measure it over say, 1 or 2 minutes and add in 5 heads (or whatever on teh bar) and then the speed you're driving? Sounds like a word problem from HS...
Will 2-4-D work on the dogbane/pigweed/johnson grass? Add something else to it?
