Hydraulic temp gauge install on BX
   / Hydraulic temp gauge install on BX #1
davesl708
Elite Member
Shawnee, KS, USA
Kubota BX2200D,
Has anyone install a temp gauge on their BX? I would like to have one to monitor HST and trans temp.
If so what gauge did you install and what problems did you have?
   / Hydraulic temp gauge install on BX #2
RaydaKub
Veteran Member
Rochester, MN
Kubota BX2230
There was a thread about 3 years ago where the guy fab'ed up heat gauge and aux cooler on the right rear fender. Look around some, I know it's here somewhere.
   / Hydraulic temp gauge install on BX #5
big bubba
Veteran Member
arkansas
M8540
have you ever had an issue w/your hydraulic system overheating that could have been avoided by having a temp gauge? wouldn't kubota have included one if deemed necessary? keeping the fluid & filter maintained, and esp. the fans in good shape would be sufficient imho. should you splice something in, be careful of the hydraulic high pressure! best regards
OP
davesl708
davesl708
Elite Member
Shawnee, KS, USA
Kubota BX2200D,
I have not had an issue yet. Would like a little warning if I am overheating the trans/hyd. fluid.
Fan is now in good shape It got trashed even with the factory shield in place.
   / Hydraulic temp gauge install on BX #8
big bubba
Veteran Member
arkansas
M8540
best of luck on your project. apologize i can't offer anything more technical on that. stay cool yourself too this summer, could be a tough one :)
