I have a really off the wall question about trenching an underground wire
   / I have a really off the wall question about trenching an underground wire #21
So that direct lighting strikes on those towers can equalize to ground without equalizing in other ancillary circuits. Like going thru the equipment to equalize. You cannot stop the direct strike, you can only supply a low impedance path for it to equalize. ground currents will still flow.
So it's lesser of two evils then?
   / I have a really off the wall question about trenching an underground wire #22
I plowed in about 900 feet of dog fence wire about the same depth. Nice black Illinois soil here tho. I fabricated a cable plow. Crossbar/square tube for the hitch. Used a 3/8 x 1 1/2 bar for the plow. Welded together. Welded a small tube with nice radius on the back of the bar. Flared the inlet. Sharpened the front of the bar for the bit that was going in the ground. Add a lot of weight. Went super slow (hydraulic drive transaxle/case Ingersoll 448 with flow control). Wire direct buried right in the ground. Ideally, the tube on a hinge would have been better. One use item for me. Still have it minus the tube. Very minimal disruption to the ground. Most places you couldn't even see it. Yes vibrating is best but for shallow and decent (moist) soil it's not required. I bet I did that in about an hour.
   / I have a really off the wall question about trenching an underground wire #23
You can't stop it. You can only help direct it. Better to equalize into your grounding system than for it to "look" for equalization thru your "stuff". We all know that ends. The surge suppression devices I recommended for each end of your equipment to protect from rising voltage gradients coming from your metallic conductor. can help clamp transients, If it is in the range that it can clamp.
   / I have a really off the wall question about trenching an underground wire #24
Instead of bury Cat6, why not just use a wireless bridge? I have a wireless bridge run to our barn at about 400'. I'm running 10 cameras on it without issue. Still have enough bandwidth when we are in the barn to be able to stream music or videos to our phones. Simpler/faster/cheaper than running the wire. 10 minutes I can set a bridge up and have internet service in the out building.
   / I have a really off the wall question about trenching an underground wire #25
What bridge are you using, I’ve been looking at doing something like this?
   / I have a really off the wall question about trenching an underground wire #26
I've put in a couple invisible dog fences with my single bottom plow. I cut the furrow, lay in the wire and roll the sod back. It's pretty darn neat and clean.
   / I have a really off the wall question about trenching an underground wire #27
Yup... Saves all that digging too.. :)
   / I have a really off the wall question about trenching an underground wire #28
You never did mention why you wanted to bury a wire or what it was supposed to carry. If it is any kind of power line the National Electrical Code gives specifications for required depth and wire types which are acceptable. Personally I would bury conduit - bigger than I thought I needed - to allow future replacement as required and to act as a gopher deterrent.
   / I have a really off the wall question about trenching an underground wire #29
   / I have a really off the wall question about trenching an underground wire #30
Yes he did. Cat 6, computer network cable.
A wireless bridge means the need for AC at the distant end. I may have missed whether or not that's available.
I used a Sub-Soiler to cut a slot about 6-8" deep to lay 3/4" conduit for the same kind of network cable. Worked fine. A little tamping and raking, a bit of seed and you can't tell where it was. No matter what you do, it will be a few weeks for the grass to fill in, so there's no reason to be too picky about it. There is virtually no way to slit or dig a lawn that won't be evident for some number of days afterwards.
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2023 HELI CPYD25C FORKLIFT (A58216)
2023 HELI CPYD25C...
2018 Doosan C185 Trailer Mounted Air Compressor, Model 484289UBACG07, S/N C185WD20T4F, Deutz Diesel (A59076)
2018 Doosan C185...
2876 (A58376)
2876 (A58376)
