I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #1
Alta krajec
John Deere 4430
I need front tires for my JD 4430, they have 11.00-16, my question is what ply of tire should I purchase? Am mainly doing field work.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #2
You should put on a ply rating equal to or exceeding the original tires. Higher is generally sturdier.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #3
Any F2 or F2M you find in that size would be designed for 'field work'. If you think the service life of whatever you have was too short, get a tire with a higher ply rating.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #4
2-WD or 4-WD tractor?
R1/ag tires or R4/industrial tires?
R1 tires are usually 4-ply, as flexibility is supposed to contribute traction. Also available in 6-8-10 ply.
R4 tires are never less than 6-ply. Also available in 8-10 ply and specialized "demolition" grades.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #5
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #6
Do you have a loader? 5 years ago I switched out my front R4's for the same size skid steer tires, with no regrets. 50% more load capacity and much thicker sidewalls.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #8
All of them.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #9
If you are doing any plowing, probably want to run tri-rib. 8 to 10 ply. Otherwise, you can go with flotation style.
   / I need front tires for my JD 4430. The size is 11.00-16, my question is, what ply of tire should I purchase if I am using this tractor for field work #10
My dealer of such only stocks 8 plies because he can put them on most tractors doing whatever needs to be done.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
2015 Toro Z Master 5000 Series 72in Zero Turn Commercial Mower (A56857)
2015 Toro Z Master...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
