I need some good advice on piping up my backhoe
   / I need some good advice on piping up my backhoe
   / I need some good advice on piping up my backhoe #12
The regen part of a loader valve means that if you select regen on the lever which is on the curl down or dump side, the fluid from the rod side of the curl cyl is sent to the base end along with the pump fluid and causes a fast dump.
You don't have to use regen, but it is there if you need it.
The valve can be mounted just about any way, sideways, vertical, horizontal , but you should mount it so it is logical in your lever movement. You know raise, lower, curl up, curl down/dump, etc
You don't have to use, but it is there if you need it.
Thank you very much for the hydraulic lessons. I have learned a lot from talking to you. This pay I will buy that spool. Im sure you will be hearing from me again.
Caterpillar 1430D Backhoe Loader (A57148)
Caterpillar 1430D...
10' Rake (A57148)
10' Rake (A57148)
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
2343 (A58376)
2343 (A58376)
