I need some good advice on piping up my backhoe
   / I need some good advice on piping up my backhoe
   / I need some good advice on piping up my backhoe #12
The regen part of a loader valve means that if you select regen on the lever which is on the curl down or dump side, the fluid from the rod side of the curl cyl is sent to the base end along with the pump fluid and causes a fast dump.
You don't have to use regen, but it is there if you need it.
The valve can be mounted just about any way, sideways, vertical, horizontal , but you should mount it so it is logical in your lever movement. You know raise, lower, curl up, curl down/dump, etc
You don't have to use, but it is there if you need it.
Thank you very much for the hydraulic lessons. I have learned a lot from talking to you. This pay I will buy that spool. Im sure you will be hearing from me again.
10' Fork Extensions (A57149)
10' Fork...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2007 CHEVROLET KODIAK C4500 (A58214)
2007 CHEVROLET...
2018 Bobcat S570 Skid Steer (A59213)
2018 Bobcat S570...
2006 International 4400DT466 (A57148)
2006 International...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
