steveja
HI all, I got a lot of great advice & help on this forum back when my BX2200 and I were younger.
I've been seeing a lot of hydraulic problems (I'm typing right now b/c I'm avoiding the greasy mess of replacing a hard FEL line - in a tight/knuckle-cutting//dirty space - again (replaced all ~9 years ago - hard job dismantling the frame). I replaced the 3 long steering lines last year after the steering wheel failed to turn the wheels. Last year also saw the seal on the RCK 60" mower gearbox fail, immediately followed by the contents being converted to glitter.
The few minor electrical anomalies were much easier to address, but frankly the starter motor still doesn't engage 100% of the time - maybe one of the 2 safety switches or ignition key switch
1/ First step - would anyone care to talk me off this ledge ?
I *think* the hydraulic problems may be caused by the very low ground clearance of the BX2200, the unprotected line locations, and the fact that I use it for more than mowing & spreading mulch. I've certainly gotten brush stuck up near the lines and those lines could even get bumped hard or 'levered/pried with a 1" type stick/branch.
Gearbox seal-fail after ~16 years is I guess just part of the deal. Nothing short of a belly-mower oil light could have prevented it. I had to weld one of the mower wheel stands, but I blame myself (or my wife when she's not too close).
Starter/electrical is the only outstanding electrical issues - and every time i go to diagnosis it, after tearing off the plastic front cowl - it works just fine. I can accept that as a symptom of age that I'll eventually solve.
I yanked the leaking fuel injectors, had 'em rebuilt ~3 years ago. Not too difficult, but ....
I really don't mind maintenance , and I do this regularly. Electrical I'm pretty comfortable diagnosing & repairing. I'd just rather not get involved in engine, transmission work esp not hydraulic problems. The hydraulic problems don't have a lot of predictive symptoms, can be hard to diagnose (where is that drip coming from ?), involves getting dirty multiple times, delays ordering parts & finding the time (and strength) to tackle.
Would a younger prettier tractor restore my tractor-love - or am I just falling onto the repetitive emotional trap ?
2/ I've been looking down the Orange list (tho' I'd consider green), and ...
As background my use is ~75% mowing, ~ 25% dragging, moving, roto-tilling. I snow plow awkwardly with the standard FEL, but since I only need that for 150ft drive a few times per year .... it's OK. I suppose I could use a pallet/bale lifter, but I don't know it it's worth the cost or the pin-on loader.
BX2360 looks like the closest replacement. The rear wheel in this 'looks' awfully small and lawn-tractorish to me, and I have a little worry about dealing w/ terrain and the occasional mud sinks. I'd probably prefer the BX2680 a little more power & torque, but there is no more FEL lift capacity nor rear-hitch - so maybe only power at the PTO which is not where I have problems. Ground clearance is 8.9inch vs 6.7inch on m BX2200. Small improvements only.
B2301/B2601 seem the next step up. With quite a bit more lift capacity, quite a bit faster, 3 speed range, 14.6 inch ground clearance. Looks very attractive.
B2650 adds cruise control, a little more speed and even more lift capacity. Starting to get a little pricey & heavy - so this is about as far as I'd look.
Others I'm missing ?
-Steve
-Steve
