Marlowe
A while back there was a discussion here regarding a refrigerator problem and the solution was right on. I've got an ice maker problem and I've been to the seemingly appropriate forums looking for help and they've been disappointing. It seems that tractor people are way smarter than refrigerator people. Just in case there's someone here who can help, here's the issue. I've got a Roper fridge built in '99, obviously with an ice maker. A while back a rat chewed the water supply tube and I turned the supply valve off to stop the leak. Recently I replaced the line and turned the water valve on to refill the ice tray. It didn't stop refilling. I understand what part of the system determines when the ice is frozen. I understand the heater circuit. I even understand the solenoid actuated water inlet valve that lets the water get into the tray. What I don't understand is how the module controls that valve. How in the world does the module know when the ice tray is full of water and to turn off the solenoid and the water flow into the tray? Mine just keeps flowing and runs water into the freezer unless I turn off the valve manually. Once I do that the system works as it should and dumps the ice, but then the water would flow again without restriction never shutting off. Is this simply the module? Did it go bad just waiting on me to replace that chewed up water inlet tube? That's what it seems to me.
