In January I decided that a small tractor would be a good investment to snow plow and grade our 300 ft dirt driveway. I decided on a tractor with FEL and a blade. I first looked at new big models and realized that the tractor with implements would approach $20,000. I then started looking at Chinese tractors both kits and from Northern Tool but read some very scary stories about Chinese tractors. I then found web sites from people selling gray market Yanmar and Kobota’s. I read lots of good things about Yanmar and about the company I ended up buying from. I think I have ended up with a good tractor (1610D), at least it is running well after 20 hours (with a few exceptions), but a few words about my experience.
1) Parts and Labor warrantees have limitations.
a. The dealer has to agree that the problem is covered
b. You have to be able to wait for the part
c. For the labor you have to be willing to pay for the 2 way shipping
A few examples:
- When I got my tractor it wouldn’t start because the Thermal Start was
bad. The dealer bought and over nighted me a TS but I had to put it
in. It starts now but never without using the TS.
- My hydraulics wouldn’t work for an hour or two after the tractor was
started in cold weather. I changed the transmission oil which fixed the
problem but the dealer maintained that they had put in new oil, which I
think that had, and felt that the hydraulics not working immediately was
normal, so didn’t pay for the oil.
- The tractor was missing some brackets, under the steps and for the
draw bar, that the dealer didn’t feel were essential and I did and do, so I
had to find and install the used parts.
- My steering had 10+ inches of play, wouldn’t adjust anymore, but my
dealer actually considered this an advantage because the steering
wouldn’t jar you if you hit a rock. I overhauled the steering box and it is
perfect now but it is a bit of money (approx $200) and a lot of work (at
least a ½ day).
- One of the 3 point pins came out and the threads were shot. I’m sure the
dealer would have sent me one but I couldn’t wait.
- Things like a mirror, horn, hood latches (My tractor only had one and a
clear plastic piece over the hole where the left one would have gone),
missing and loose bolts, fuse cover, PTO shield, clutch interlock,
grommets on dash, tire valve caps, my dealer and probably your dealer,
may not consider part of the package. So if having everything working is
important to you, expect to spend some sweat and money to get it all
working.
2) If you don’t like what you see when it arrives you have very few options
For example
- I was shipped a different tractor than I was sent pictures of. I’m
pretty sure it was an honest mistake but it is a risk you take buying
something sight unseen. If you pay cash you have very few options.
- My tractor had not been repainted, and did not have new hoses or belts
that had all been promised when I was told that most people that buy
their tractors “think that they are new”.
3) Because these are 30 year old tractors and unless the dealer is close you
will do all the work yourself so you need the time, inclination and expertise
to do the work. Along with all the work above I have put in the proper
fuses in (had one that was a 32 volt 30 amp fuse instead of a 12 volt 10
amp), replaced the light switch which the dealer bought, fix a FEL oil leak,
properly adjusted the clutch and belt, and put on a new FEL control valve
because I realized I needed a float control. In the future I need to fix a
leaking seal in the transmission (dealer bought the seal) and am planning
on doing lots of painting when it gets warm enough (dealer bought me
some spray paint).
Bottom line is -- I think I now have a good tractor for less than half of what a new Japanese made tractor would have cost, but you have to take a bit of a risk and plan on investing some of your own money and time. If you have a warrantee it is really for parts and catastrophic repairs.
A few examples:
least a ½ day).
working.
For example
some spray paint).
