Info on 5234D
   / Info on 5234D #1
kcook
Platinum Member
MI
Cub Lawn Tractor
Just looked at a 5243D, it came with a loader and 60" mid mount mower for 12800.00. Is it a good unit, is this a good price? Does the loader come off buy removing the two front pins?
KC
   / Info on 5234D #2
I've got about 140 hours on a 5252 with a 60" mower and loader. I've moved over 100 tons of gravel, dug a 16X32 ft inground pool in addition to mowing 5 acres weekly and tilling and spraying duties. It is very strong and well built. I would highly recommend this model. The diesel and 4wd should only make it stronger.
   / Info on 5234D #3
I have a 5254 with a 60" MMM and FEL. To remove the FEL all you have to do is pull the two pins in the front and disconnect the four hoses - takes less than 5 min.
   / Info on 5234D
How is this tractor running attachments?
Thanks for the info:)
KC
   / Info on 5234D #5
I have not used the FEL much, but it does work good. I use the 60" MMM every week - that works great, good clean cut.
I have been looking for a backhoe attachment for it. I was told that Cub would not offer one this year. Talked to the Woods factory and was told that they have not designed the brackets for the 5254 yet - maybe later this year.
   / Info on 5234D
Can anyone give me a idea about price for the tractor, FEL and 54/60 MMM?
KC
   / Info on 5234D #7
I got the 5252 with 60" MMM and FEL for $9800 delivered. The MMM is a bit of a pain to get on and off and if you will be using 3pt hitch implements there is no separate lift for the 3pt and MMM.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
71053 (A49346)
71053 (A49346)
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
