injection pump questions
   / injection pump questions
I took the cover back off 3 times to check if stop lever was lined up properly I did have to unbolt the pump to tip it forward because I dropped the spring and stud that holds the governor spring to the gov. arm inside injector. I did not pull it away from the housing just tipped it down so I could get my tiny magnet in side to retrieve pin.I tipped it back up never disengaging the gears that turn the pump. I placed it back on 0 degrees. I know I have the gov. spring in the proper holes center on gov. arm center hole on throttle link. I am at my wits end this is driving me nuts, I am stuck in a customers back yard for 3 weeks. I cant move or tow tractor it has back hoe and bucket that are on the ground. do you know of any way to get the bucket or hoe up? so I can move it?
   / injection pump questions #22
Bucket is easy to raise when towing. Just attach chain from towing vehicle putting chain under bucket to tractor frt axle. When chain is tightened bucket will raise when FEL control valve is operated. BH could be pulled up with the aid of engaging the starter.
Greenhouse Panels (A50860)
Greenhouse Panels...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
Root Rake (A48083)
Root Rake (A48083)
ATV Racks (A50860)
ATV Racks (A50860)
