Is a fully discharged battery now junk?
   / Is a fully discharged battery now junk? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I mistakenly fully discharged the battery in my MX 5100 Kubota. It was a replacement likely made by Interstate. The battery was so dead it even tripped the 50 amp main fuse and I didn't know it could do that.
Anyway, I've been slow charging that battery but I have the feeling it's no good after a full discharge like that. Anyone know about this?
   / Is a fully discharged battery now junk? #2
My understanding is it actually can be good for them to be discharged then charged fully back up. Try it and see.
   / Is a fully discharged battery now junk? #3
Ive fully discharged batteries-even 2 of them- in larger tractors and they always recharged for me.
   / Is a fully discharged battery now junk? #4
I've discharged a new battery, charged it back up and it came back full. Been lasting 5 years now
Wow, thank you all for the voice of optimism.I've bought a lot of batteries this year and don't need any more.
It must be an old wive's tale that fully discharged ruins a battery. Or maybe that was in the olden days. These days I charge batteries just before the cold starts and I've had great luck with longevity.
   / Is a fully discharged battery now junk? #7
Fully discharged from slow leak is ok 1ce or twice & maybe 3 times. High discharge can swell/ruin the plates, especially if water level is way down. Using distilled water is best but hardly anyone pays any attention. Mineral water == slow short circuit. Plus, high charge rate bubbling puts acid on the case top so another slow death/drain. Some batteries can last 20 years. some last 2 years depending on how careful and respectful you are with them. No battery: no tractor is how I respect them.
   / Is a fully discharged battery now junk? #8
Only one real way to find out, charge or jump it and see what happens.
I needed the tractor so put a spare in and the discharged battery is on a 3 amp slow charge "smart" modern charger. I never understood boiling the cr*p out of them with a high amp fast charger.
I'll let it slow charge longer and then see what happens. All good to know.
   / Is a fully discharged battery now junk? #10
Discharged batteries start to oxidize the lead plates. Leaving batteries discharged for extended periods is definitely bad.
Single time and it was charged fairly quickly….may not be a certain death sentence.
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
2020 PETERBILT 567 SLEEPER TRUCK (A56138)
2020 PETERBILT 567...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
