Is there a doctor in the house?
   / Is there a doctor in the house? #1
Bowhunter
southwest Indiana
Kubota BX2200
Please diagnose my Kubota problems. Last week I installed 4 new glow plugs in my B9200 and blew out the air filter. When I tried to mow Saturday it didn't run right from the start. It smoked much more than normal, ran rougher than normal, and lost power easily. My guess is that while moving parts out of the way to get to the glow plugs I jostled some junk in a fuel line and the junk is now plugging the fuel filter. Anyone have any other ideas?
Another problem occurred later in the day. On the B9200 the rear and mid pto's both run at the same time. After mowing for around 2 hours I started hearing a whine from the rear pto area. It stopped when I turned off the pto, and returned when I turned it back on. I'm assuming a bearing or something in the rear pto. My question, does the rear pto have any grease zerts (a problem I can fix) or does it run in an oil bath (a problem I'll unfortunately have to pay someone else to fix)?
Thanks for any help!
   / Is there a doctor in the house? #2
Well I am not real familiar with the 9200 but I am pretty sure that the PTO lubrication is basically the transmission fluid. The rear PTO generally runs right off the rear differential and is therefore lubed through the main transmission bath. So just make sure your rear hydrolic/transmission well is full to the right level.
As for the other problem your diagnosis makes sense and is pretty easy to check. On my B7500 the fuel filter is easily checked/cleaned.
Good Luck.
MC
2016 Chrysler 200 Limited Sedan (A48082)
2016 Chrysler 200...
2012 Dodge Grand Caravan Van (A48082)
2012 Dodge Grand...
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
Pallet of Chains/Binders/Cable Slings (A50860)
Pallet of...
1991 Deere 750B Long Track Crawler Dozer (A50860)
1991 Deere 750B...
2020 KUBOTA RTV...
