ISO mount replacement process *with pics*
   / ISO mount replacement process *with pics* #1
gdechatham
Hello all,
I finally had the time to replace the ISO mounts on my 1450 Quietline Cub Cadet. What a job! It took 4 hours 30 minutes just to replace the ISO mounts. (Even though I work fairly fast with no breaks) So, I thought, why not share the whole process with guys here.
First, I had to research ISO mounts. I had 3 possible choices:
  • 1) Buy a MOOG car suspension mount kit (Cheap rubber mounts)
    2) Buy the original Cub Cadet ISO mounts (Expensive, but correct ones)
    3) Buy steel milled ISO mounts made by Brian Miller (Very reasonably priced, but steel- not rubber)
So, what to do? After much research, I found that most owners that has used the MOOG mounts has said that the MOOG mounts will have to be replaced eventually, as they wear out fairly quickly. Other owners that used the original Cub Cadet ISO mounts has said that they work great, but they take time to become 100% effective, as they are stiff at first. BUT, they are expensive at $16.00 PER CORNER plus shipping, totaling approximately $80. Lastly, Brian Miller makes steel milled ISO Mounts. Some people have said that there's a vibration issue. Some people has said that they worked great with no change in vibration. But one thing remains the same: the steel mounts NEVER has to be replaced, and the steel rails remain solid in place. I finally decided to go with Brian Miller's ISO mounts- the best decision I could have made.
Here is a picture of ISO mounts that Brian Miller made:
I got the mounts in the mail for a VERY REASONABLE PRICE. ($30 shipped to my door for 4 mounts) I STRONGLY recommend his mounts and his other products that he has to offer. He is very honest and has a fantastic selection of products for Cub Cadet tractors. Thank you, Brian for the mounts. Very much appreciated!
This is his page for those that are interested:
Brian Miller's Links & Home Page
As I mentioned above, some people experienced some vibration with steel mounts. With that thought in mind, I decided to install a thin rubber washer under the steel mounts. This is the kit that I put together along with the ISO mounts that Brian made:
(4) grade 8 bolts, (4) nuts with rubber lock, (8) hardened washers, (4) rubber washers, (4) Brian Miller's ISO mounts.
Before I started, I realized that I had to lift the 120 lb engine out of the tractor in order to replace the mounts. So, I had to reinforce the beam above by adding another piece of wood between the cross beam and one of the roof beams.
I had to disconnect all the wires, gas line, transmission connection, pto belt (for mower), remove the gas tank & firewall, jack up the tractor & remove the front axle to get to the front engine bolts, disconnect the engine from underneath, then finally, I used winch straps around the beam going down to the engine. I didn't have anything else to use. So, I had to apply some redneck ingenuity to get the engine out. I used 2 winch straps- one to jack the engine up, the other for safety.
Full view:
I took out the rails and I was amazed to see one rail that was in great condition, and the other one was gouged. The one that was gouged- the gouge was as deep as a quarter! It must have been like that for a while. The engine was tightly bolted to the rails by brand new bolts, so the previous owner must have redid the mounts as recent as last year. (The mounts got destroyed again anyway, and they were that way when I got the tractor last month)
See the gouge and damaged mounts. The mounts must be a year old, 2 years maximum! (Left side)
This is the right hand side, the rail was undamaged, but the mounts were already mostly gone.
I put the steel mounts in, alongside with the rubber washers- fit like a charm! I solved the problem with the winch straps not having any way to lower the engine slowly by jacking up the tractor itself to the position where the engine was jacked up by the straps. Worked very well. Slid right in with no issues. (I had replaced the rails and mounts with the engine 5" above the tractor frame the whole time)
I would have taken pictures of the axle and other proccess, but at this point, after going through all the grief of getting the engine out, I wasn't in the mood to take pictures- I wanted to get the job done. I put the engine back in, hooked everything up. Tractor started and drove great!
The 1450 Quietline tractor as it is today:
Comparison of before and after:
The tractor shook a little bit before, due to the mounts being gone. The vibrations were unbearable, because my feet were numb after riding the tractor for 5 minutes. As I went over bumps, I could feel transmission surging, because the engine would move forward and backwards. (Not good!)
Now that the mounts are in, the engine stays right where it is. (It isn't going anywhere with Brian Miller's mounts!) The vibration is much less than it was before. There are SOME vibrations, but it doesn't leave me with that foot numbing. It was definitely worth it, and most of all, I don't have to go through this again. :D
Cheers,
George
   / ISO mount replacement process *with pics* #2
Holy Cow! we must be neighbors...the upper part of our garage is like identical to yours. 4 years ago we totally reinforced it. And here I thought I had a totally unique home owner built garage.
Anyway I have a 1440 HST that still running strong but someday I'll be putting your ideas to work.
   / ISO mount replacement process *with pics* #3
George, my browser isn't displaying any pictures. I was able to replace my 1450 mounts without removing the axle, just the tank, driveshaft, sheetmetal etc. Of course my engine mounting bolts were gone so I didn't have to remove the old ones - just install the new ones. I trusted the 2 x 6 in the roof of my double garage and threw a chainfall over it. Glad it went well for you.
Bob B.
savageactor7,
LOL, Our detached garage is old, from the 20's. Unfortunately, the previous owners didn't care much about the roof and allowed it to leak for years. The house had been 100% renovated, but we didn't have enough left to do the garage. But, hey, it works. :D
We'll be moving to Florida in 3 weeks and leaving that garage behind, so I didn't mind if the roof fell down- just didn't want to flatten my Lincoln Town Car that was parked inside the garage. :eek: I sure am looking forward to the new garage in Florida- it's brand new with air conditioning. :cool:
Bob,
How did you remove the bolts without removing the axle? At first, I jacked up the tractor and pushed the tire in one direction, allowing for some clearance... My socket wrench wouldn't fit in there. (I used a flat mechanic type socket wrench) Unless, you lifted the engine with the rails still attached to the engine?
As for the x's, yeah, I know... It's a server problem at Geocities, which I used primarily to host the pictures that I posted here. It's unreliable. I did post a good post with pictures at:
Farmall Cub • View topic - ISO mount replacement process *with pics*
I would change the links in this forum to the links that I used in the other post, but that server belongs to the farmall forum. It wouldn't be appropriate for me to link to there from here, so I left the link to the whole post above in case you wanted to see a post with all pictures there. My apologies again. It's one of the downfalls of having to link to pictures rather than downloading pictures directly to the forum server like www.simpletractors.com does.
Sincerely,
George
   / ISO mount replacement process *with pics* #5
That worn frame rail--did you replace it or weld it up or did you reinstall it? At least from the pictures, can't tell if you did the cross brace frame rail modification....
Was your oil pan worn down or did you get to this problem in time to save the oil pan?
Friend of mine wrecked his back putting one of these back together. You were very smart to hoist it instead of trying to muscle it.
2manyrocks,
After I installed the steel mounts on the good rail, I realized that the rail was not going anywhere. Also, the engine's mounts on the oilpan were not ruined at all. That was very fortunate. The previous owner put in fresh grade 8 bolts & lock washers in, and the engine was still very tight after me using it for a month mowing the lawn on a very bumpy property with bad ISO mounts.
Bearing these things in mind and since I didn't have a good left rail on hand and since we were moving to Florida in 3 weeks, I decided to just reinstall the gouged rail as is and use the tractor for a while. After I have thickened my tractor collection once again in a few years, I might take the 1450 apart completely and restore it completely. I won't have to do the rail modification- the rails are very tight in place, with grade 8 nylock nuts.
I've used the tractor twice since the ISO mount re-installation, and the engine is still tightly in place. Will be keeping an eye on it for a while to be on the safe side.
Sorry to hear about your friend that had wrecked his back. That must have had been painful for him. After seeing how much it weighed in the Kohler Service Manual, I just knew what had to be done. For the next time, I think that I'll be buying myself an electric winch and attach it to the beam above in my new garage. That'll put a grin on my face for sure. ;)
   / ISO mount replacement process *with pics* #7
After giving this more thought, I can see that the metal mounts take the flex out so the cross rail is not needed.
The older IH Cubs had the motors mounted directly to the frame.
A cherry picker is also good for removing and installing these engines in the older Cubs. It can be a pain to get those bolts lined up to reinstall the ISO mounts. To me, there is something about the weight of the engine and being bent over to try to get things lined up that can cause a back injury if you try to muscle it instead of using some kind of mechanical lift.
Feels good to get it back together, doesn't it?
2manyrocks,
:D sure does. Just wanted to mention that the ISO rails were very easy to install with the metal mounts- I didn't have to worry about lining up anything- it just bolted on and when I jacked up the tractor to match the height of the engine, the bolts lined up perfectly as it is.
I believe that Brian Miller (The one that machined the mounts) must have really took the time to measure and figure out exactly how tall the mounts had to be, so that no adjustments were needed.
Cheers,
George
   / ISO mount replacement process *with pics* #9
savageactor7,
Bob,
Sincerely,
George
George, my bolts fell out so the engine was free to be lifted out. Somehow I was able to find the right combination of tools to install the new bolts with the axle in place.
BoB B.
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
International 574 2wd Tractor (A52128)
International 574...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
