JD 2305 Homemade Cab Build
   / JD 2305 Homemade Cab Build #11
What did you use for the frame?
I used 1"x2" box tubing from a large shelving unit. It worked out perfectly for the frame and although it has some slots in it, they don't hurt anything!
   / JD 2305 Homemade Cab Build #13
My estimated total cab cost was around $1,000-$1,200. Comparable aftermarket cab was roughly $4000. I am not a metal worker!!!! A woodworker and metal rarely mix, but I had a great time making this for my dad. As for the the attaching of the lexan, I used a 1/8 inch self adhesive foam padding in between the frame and the lexan to stop any vibration. As for fasteners I used 5/8 inch #10 Stainless Steel Self tapping screws. I pre drilled through the lexan and metal before using the self tappers. The foam padding worked perfect, however the screws have to be carefully put in to the right depth so that the lexan does not become wavy. I was concerned that screws may rip out, but that was before I had ever had any experience with lexan.
Thanks for your inquiry
God Bless,
Nathan
If it makes you feel any better, metal workers rarely do well with wood.
As for the waviness with lexan, I've found that a flat washer sized to be very close to the foam gasket thickness, give the screw something to tighten to, with out excessive warp.
   / JD 2305 Homemade Cab Build #15
hi nice build would you happen to have a drawing of the build
thanks Colin
   / JD 2305 Homemade Cab Build #16
Sorry Colin Small engines, I did not take the time to do any drawings. If you need any further pictures or measurements I can get them for you.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
1989 CAT D30D Articulating Dump Truck (A59213)
1989 CAT D30D...
Club Car Utility Cart (A55851)
Club Car Utility...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
