JD 2320 3rd and 4th SCV valves
   / JD 2320 3rd and 4th SCV valves #1
nyen0004
Morewood, Ontario, Canada
John Deere 2320
Hey Everybody, I am in the process of installing a two spool valve on my JD 2320 so I can have two sets of coupler's at the rear of my tractor for attachments. I know that I need to attach the new SCV to the auxiliary plate just behind the loaders SCV, but the thing I need you guys help for is which plug on the bottom of the auxiliary plate is the Pressure and which is the Return. I know there are a few guys on this forum that have done this, so wondering if you guys would share your knowledge. I guess I can do a trial and take a guess at it, but not sure what will happen if I feed pressure into the new SCV in the wrong direction. Any input would be greatly appreciated
   / JD 2320 3rd and 4th SCV valves #2
Here you go, don't forget to install the little set screw/plug or nothing will work correctly.
FYI the 4110, 2320, 2520, 2720 all use the same setup so don't limit your searches to the 2320. There are quite a few great threads on adding remotes to 2520's.
Thanks kennyd,
I was actually thinking the opposite so I'm glad you clarified that with me. I was planning on going 3/8" hose to the valve and 1/4" hose from valve to couplings. Will this work fine?
   / JD 2320 3rd and 4th SCV valves #4
Yup, good plan.
Good, I'm glad I was going on the right path. Thanks Again
Walking Floor Trailer (A44571)
Walking Floor...
2016 Autocar Xpeditor T/A Heil Side Loader Garbage Truck (A44571)
2016 Autocar...
More info coming soon! (A44572)
More info coming...
Bauman 90" Produce Bucket (A47369)
Bauman 90" Produce...
Gallenberg 750XT AireGlide Sprayer (A47369)
Gallenberg 750XT...
2025 Wolverine BC-13-72W UNUSED 72in Brush Cutter (A47484)
2025 Wolverine...
