JD 3038 - Enough power to run a logsplitter?
   / JD 3038 - Enough power to run a logsplitter? #1
joejohn
Alright...I'm getting the dual rear remotes installed on my new JD 3038...
I'm also looking at the Power Beyond Kit to run a log splitter, I had thought about running the log splitter from a pump on the pto, but forgot that if there was no one ont he seat, then the pto won't run!!! LOL!
Anyhow...will a PB kit with the 3038 be enough to run a log splitter?
What determines the force for a log splitter, the GPM or the PSI? or a combination of the both?
any help would be great! My tractor says the implement only has a hydraulic flow of 5.3 GPM, will this be ok??
   / JD 3038 - Enough power to run a logsplitter? #2
The pressure and the diameter of the cylinder, work together to give the force. Increase either one, and the force increases. The GPM determines the time for extension and retraction.
cyl psi lbs ton
3 in at 2500 = 17,671 = 8
4 in at 3000 = 37,699 = 18
6 in at 3000 = 84,823 = 42
   / JD 3038 - Enough power to run a logsplitter? #3
It may be a touch slow...but it will operate it fine and have plenty of power. There may be a way to defeat the safety switch for off-seat operation also...on my 4110 I simply pull the switch up after raising the seat, most JD models have tat ability somehow-check your manual.
   / JD 3038 - Enough power to run a logsplitter? #4
cyl psi lbs ton
I am curious to see how you come up with your numbers JJ.
   / JD 3038 - Enough power to run a logsplitter? #5
Seems like the formula would be Area (in sq in) times pounds per sq in.
3" dia. cylinder = (PI X (1.5 squared)) X 2500
Dave.
   / JD 3038 - Enough power to run a logsplitter? #6
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
2020 John Deere 9470R Tractor (A50860)
2020 John Deere...
UNUSED Safety Traffic Cones (A50860)
UNUSED Safety...
2020 Bell B30E Off Road Dump Truck (A50860)
2020 Bell B30E Off...
2017 Dodge RAM 1500 4WD Pickup Truck (A50860)
2017 Dodge RAM...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
