It's 1000 hr interval between hydrostatic fluid changes.......I bought the tractor with about 1700hrs on it from a dealer in Northern Wisconsin. I agree on "don't skimp".....you get what you pay for (used Hyguard fluid). I do the same with my Bobcat.
I hold the dipstick up to the light to see if the level is good (yellow fluid on yellow dipstick......not sure why they put those two together).....though I can see how a red dye would help.
I have an '09 3720 Open Station and here is a direct quote from the manual:
Servicing Your Machine
Please use the following timetables to perform routine
maintenance on your machine.
As Needed
• Replace alternator belt.
• Replace air filter elements (see air restriction indicator).
• Replace cab air filters.
• Replace light bulbs.
• Replace fuses.
• Clean and replace battery.
• Replace radiator hoses and clamps.
• Check tire air pressure.
• Clean fuel tank overfill reservoir.
• Drain water and sediment from fuel tank, and service
water separator.
• Check and adjust front wheel toe-in.
• Check and clean grille and side screens.
• Check and clean radiator cooling screen.
• Clean debris from engine compartment.
• Adjust all cables to acquire appropriate travel for
engagement (cabs).
After First 10 Hours
• Check wheel bolt torque.
• Check cab rollover protection system mounting hardware
torque.
• Check windshield wiper arm mounting hardware torque.
Every 10 Hours or Daily
• Test safety systems.
• Check engine oil level.
• Check transmission oil level.
• Check air filter rubber dust unloading valve.
• Check radiator coolant level.
Every 50 Hours
• Check front axle oil level.
• Lubricate machine.
• Check cab protection system mounting hardware torque.
• Clean or replace cab air filters.
Every 200 Hours
• Change engine oil and filter.
• Inspect alternator belt.
• Check air restriction indicator light.
Every 400 Hours
• Change transmission oil and filter.
• Replace fuel filter.
Every 600 Hours
• Check engine low idle speed.
• Check air filter intake hoses and clamps.
• Change front axle oil.
• Check front axle thrust bolt torque.
• Check brake adjustment.
Yearly
• Change engine oil and filter if less than 200 hours of
operation.
• Drain water from fuel tank and replace fuel filter.
• Check all hoses and clamps.
• Check battery electrolyte level.
IMPORTANT: Avoid damage! Operating in extreme
conditions may require more frequent service
intervals:
• Engine components may become dirty or plugged
when operating in extreme heat, dust or other
severe conditions.
• Engine oil can degrade if machine is operated
constantly at slow or low engine speeds or for
frequent short periods of time.
Every 1200 Hours
• Check and clean inline hydraulic filter.
• Check engine valve clearance. See your John Deere
dealer.
Every Two Years or 2000 Hours
• Flush and replace factory coolant. Flush cooling system
and replace coolant with John Deere COOL-GARD engine
coolant.
• Service fuel injection nozzles.
