JD 4115 Lift arms won't lower
   / JD 4115 Lift arms won't lower #1
enrgyadv
John Deere 4115
I have a similar problem that I have seen posted here before but no resolution yet. I bought a 4115 and didn't realize that the lift arms were stuck in the up position. I've taken the control valve out about three times now and have disassembled it and found no issues. I took the rocker arm housing cover off and inspected. I finally took it to the dealer and they said it needed a new control valve for $2,200 although they said it could be more if thats not the problem. I think they are just doing the plug and play thing. The odd thing is that when I brought it home after having the dealer look at it and not fix it the control arms would fall once the tractor is shut off. Upon starting they go right back up. I see reference to an "isolation valve" in the repair manual but can't see where that is located. Any help would sure be appreciated.:confused:
   / JD 4115 Lift arms won't lower #2
Hi. I have the same thing happening in my fiat 650 tractor. Not the same machine but word is the drain valve is stuck. Engine off= arms down. Engine running = arms up. Hard to diagnose on the fiat as the whole hydraulic tank has to be removed to get to the drain valve. Not hijacking your thread sorry but maybe if your tractor is similar it might be worth looking into this. Cheers.
   / JD 4115 Lift arms won't lower #3
Looks like your tractor has a rockshaft lock valve.
Operating
Ryobi Sliding Compound Miter Saw (A48837)
Ryobi Sliding...
More info coming soon! (A46684)
More info coming...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
2021 Chevrolet Tahoe SUV (A46684)
2021 Chevrolet...
Side Dresser (A49251)
2015 Ford F-750 Terex Hi-Ranger 5TC-55 55ft Insulated Bucket Truck (A46683)
2015 Ford F-750...
