Tiller JD 445 tiller pto speed?
   / JD 445 tiller pto speed? #1
Bowhunter
southwest Indiana
Kubota BX2200
My dad has a 455 garden tractor and a 445 rotary tiller (54" pto driven). I have a Kubota BX2200 and am hoping to find a pto adapter that will let me hook up the pto shaft to my tractor. My tractor has a regular male end on the tractor, while the tiller's pto shaft also has a male end.
My question is does anyone know the pto speed of this tiller? I know some cat. 0 equipment runs at 1000 rpm. My tractor runs at 540 rpm. I want to make sure I'm not wasting my time finding an adapter if the speeds don't match. Thanks.
   / JD 445 tiller pto speed? #2
Per the owners' manual, the 455 is equipped with a 2000 rpm mid PTO.
Ours doesn't have the rear PTO and there's no mention of it in the manual.
I believe rear pto and lift was available as an option only. I learned in the lawn/garden section that the rear pto is 540, so everything should work for me. Thanks.
   / JD 445 tiller pto speed? #4
I'm planning on adding a 42" bushhog to my 455 this year. The standard rear PTO is 540 female. The dealer sells a $65 male shaft to adapt it to a conventional PTO. Methinks your tiller male end is setup to connect into standard PTO config.
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
Utility Trailer (A52377)
Utility Trailer...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
Dump bed (A51692)
Dump bed (A51692)
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
