JD Backhoe 260 ???
   / JD Backhoe 260 ??? #11
Good luck with your search gasman, as long as you aren't expecting full size hoe performance, the 260 is fun to work with.
   / JD Backhoe 260 ??? #12
How have you broken the hoe a couple times? I'm interested because I have one (relatively few hours on it).
One was grease issue, one particular pivot pin(one of the pins between the two booms) was not getting nearly enough grease as the zerk was very stiff and pretty difficult to get at. The pin seized than sheared which twisted the one boom. Nothing a good welder(machine shop) didn't fix.
A couple of hydraulic hoses have also burst. We also had a bushing fail at the weld.
I would just recommend lots of grease on the pins. Also tree root ball removal is NOT recommended. Stick to easy tasks and you will mostly be fine.
   / JD Backhoe 260 ??? #13
Welcome to TractorByNet!
I moved your thread to the John Deere Owning & Operating forum. :)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2229 (A58376)
2229 (A58376)
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
2025 Swict 60in Bucket Skid Steer Attachment (A56857)
2025 Swict 60in...
Yanmar YT359 (A53317)
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
