Jinma 354 transmission and hydraulic fluids…which ones?
/ Jinma 354 transmission and hydraulic fluids…which ones? #1
DonRina
Bronze Member
Vancouver Island
Jinma 354
Hi all, Along with my various deferred maintenance projects for my Jinma 354 I’ll have to swap out the transmission fluid (while I'm doing a brake job) and I’ll give the hydraulics one more flush as I had to open the three point lift mechanism. Is gear oil 80/90 gl-5 ok to use? I should mention temperature range here is -5 c to + 25c or so.
I ‘ ve been using the iso 32 hydraulic oil so far…seems ok. Any issues with that oil?
I can get both oils from Walmart for $88 CDN for 20 liters which is way better than our Canuck Tire.
Thanks for any info.
/ Jinma 354 transmission and hydraulic fluids…which ones? #2
If it has wet brakes and/or wet clutches, you'll need UTTO (universal tractor transmission oil) which has the right additives for wet brakes and clutches.
Well they are both dry on the 354
