John Deere 2305 Compact Tractor Transmission and rear PTO failure
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #51
Anyone know how the 1026r PTO compares to the 2305?
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #52
I don't know the design, but I think that Deere wound have completely redesigned the case. They were aware of the issue.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #53
I have the identical issue, It looks the exact as your pictures. It happened when using my John Deere rear mower IN MY YARD < 100 hours. I always loved JD but they way this is being handled is absurd and wrong, when I wen to the dealer, Maple Mountain, I was told they had 2 others with same issue, they offered no discount or assistance in anyway other than saying approximately 6000.00 to repair. I removed the broken parts and only use the lower PTO. If there is anything I can do to help press the issue let me know.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #54
What happened to break your case. Some have had success with their home insurance covering the repairs if it hit something.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #55
The external case is obviosly a complete redesign. Not sure of the inside. I do know the new 1 series transaxle/pto case is no longer air cooled but is now oil cooled, which tells me they went to a thicker case maybe. They do know there's an issue and have no intention of issuing any kind of recall. Just hoping my 2210 holds up till I can upgrade to a 1 series in a few years.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #56
Why not go to the 2 series instead? Pretty much the same money.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #57
I sympathize with you and your serious trans/pto trouble, and agree that any self respecting manufacturer should stand behind their products better than that. Do you have BBB ( Better Business Bureau ) down there? If you do it might not hurt to see if they might step up to the plate for you too. Even though your tractor is past time date, those low hours should definitely be considered by JD.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #58
I'm sure there are benefits to the 2 series, larger wheels and tires for one. I wish to remain with the smaller 2210/2305/1023 type because of the HDAP tire option which I feel is the perfect tire for my multipurpose needs at this time. Also, the 2320 has no more power and the 2 series have a weekness in the rear final drive. What I'd really like is a 3320 cab tractor but have no building suitable to shelter it, nor the funds to aquire them.
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #59
Which weakness are you referring to in the 2 series?
   / John Deere 2305 Compact Tractor Transmission and rear PTO failure #60
Cracked housing where the three point lift arm attaches.... Aluminum is light duty.... where might I find a used transmission?
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
5004 (A55851)
5004 (A55851)
2020 Nissan Rogue SUV (A55853)
2020 Nissan Rogue...
