Item Details
- Make
- John Deere
- Item status
- Sold
I have a John Deere Tractor that I am selling whole as a parts machine.
Parts from this tractor will fit 4200 4300 4400 4500 4510 and others I am told.
This tractor is a 2000 John Deere 4200 tractor serial # LV4200H321983 4 wheel drive with Hydro Transmission and loader control valve with joystick
- Yanmar 3TNE78A motor Runs Great. I have a video of it running.
The muffler is included and all of the fuel lines have been capped off.
I might keep the starter and alternator. 3,839hrs roughly
- It has a Hydro Transmission that works well ...New Hydro oil cooler
- The rims are rusty cause they loaded salt but the tractor was maintained fairly well. Tires are not loaded I am told Fromt tires have decent tread on them. Back tires are useable.
- The Hydraulic steering is intact and functional. Steer cylinder shaft bent but operational and not leaking.
- The rear end is also in great shape.
- The front differential works fine. The right front knuckle is cracked and off of the machine. A quick look makes me think it could be repaired. Parts are in a box.
- The radiator and cooling system is full, sealed and fully functional
- The 3 spool valve and loader joystick is intact and fully functional(I operated the loader before disassembly)
- The hydraulic pump, starter and alternator are also included. (Special short Starter)
- All 4 tires are holding air and the fronts actually have nice tread. The rims are rusty.
- The 4wd is functional except for the R/F broken knuckle
- Parts for the 3 point hitch. No top link
- I might keep the wiring harness.
- The chassis is still assembled
The bad...The linkeage rod that goes through the rear housing for the range selector broke and the tractor is stuck in high range. Tractor is in high range currently. I think I have a way to fix it.
And the right front steering kuckle is broken
I drove the tractor for about an hour or so working all of the hydraulics, brakes and mechanicals. It last ran roughly february 1st 2021. I have a video of it running. All systems were functional at that time.
There are some more miscellaneous parts included but if I didnt mention it I do not have it.
I want to sell it all together but depending on what you want and what you offer for it I might break it up.
$3,500 as is and as stated.
Pickup in Columbus Ohio I think I can get it up onto your trailer
