John deere 820
   / John deere 820 #11
What is involved with changing the o ring on the pto lever?
Removing 3 pt cover then removing spring pin to get shift lever out of trans case to renew o-ring and reassemble in a very hard to access place. A very difficult task.
   / John deere 820
Thanks for the help. Will keep y'all posted. Anything else I need to know about these little tractors?? Are they reliable?
   / John deere 820 #13
Very reliable tractor. Bought one in 1972 and still running good today. Good to use for grading, bush hogging, cutting and raking hay, etc. o ly real problem rear hydraulic leak as mention by others but not a major issue. Agree need two good batteries. What is overall condition of tractor? If you decide you don't want to keep it, let me know for I might be interested.
   / John deere 820 #14
I remember when I sold those 3 cyl 820's when they were new. First tractors I had sold that were built in Germany and I was very skeptical. They turned out to be very good tractors just deliver them & forget them hardly ever any warranty work was performed on them.
   / John deere 820
I will let you know. The tractor is in fairly good shape. Sheet metal is decent just missing battery cover and side screens. It has a new clutch that was installed three years ago. It spent most of its life on a ballpark running a finishing mower. Overall it's decent. It does have turf tires on the rear and will be looking to replace them with regular tractor tires. If anyone knows where I can maybe get the sheet metal parts I need let me know thanks.
   / John deere 820 #16
Every now and again you can find leads on on E-Bay. Ascension Equipment in Gonzales can get new but oh so pricey.
   / John deere 820
Thanks for the info. Hopefully this week I can work on it and see what it will do. Hopefully it will run ok
   / John deere 820
   / John deere 820
One more ques, where is the dipstick for hydraulic and transmission,
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2016 Volvo EC220EL (A55272)
2016 Volvo EC220EL...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
