kama ts254c clutch
   / kama ts254c clutch #32
lakespirit said:
Is there supposed to be teflon tape on the threads or a washer of some sort on that flared fitting?
As far as the leak goes I doubt it needs a washer. Usually those type of fittings seal themselves. Try polishing both surfaces of the flare with some steel wool then clean really well. It probably has a small burr you can't see.
Dwayne,
I tried a couple different times cleaning and finally put a very small amount of silicone sealant on the head of the fitting and the threads...so far no leak. I'm sure the polishing helped a lot as well. Everything is working now!
Thanks for all your help.
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
3-Point Single Disk Plow (A50860)
3-Point Single...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
