I borrowed my father in laws 6 foot king kutter gear driven tillar, model TG-72-YK. It has only been used a couple times and today I hooked it to a 65hp tractor to start breaking up a food plot we plan to start next year. After about one acre smoke started billowing out of the slip clutch so I will need to change it out next weekend.
Is it as simple as undoing the bolts and everything will slide apart then put in two new disc and tighten back up?
I was going pretty slow the tractor has 8 gears plus 2 ranges and I was in low range 3rd gear. The tiller was set to the next to lowest setting.
I guess I. Should raise it up then after done once lower it down and go a second time?
