This is a repeat of a question about the PTO on a 2018 Kioti CK3510HST. I think the original question was posted in 2019 but when you are old, time flies, minds wander. At that time, the PTO would not engage after sucking up a piece of 4x4 into a flail mower while clearing some tall brush. The mower ate the belts which I replaced but I could not engage the manual lever for the PTO. It is attached to a shaft that goes into the case under the operator's seat. From the first posting I got a couple of suggestions for things to check, but nothing fixed the problem. Then after switching implements, (mower to box blade to back blade), the PTO started working -(mystically/ magically - I guess after praying to the Coyote gods). I mowed in 2020 with no issues other than replacing belts on the mower. This year I was out mowing and the PTO lever disengaged on its own. I was able to stop, re-engage the PTO and continue mowing. This happened again twice in about three hundred yards and now the PTO lever will not engage. Engine, transmission, FEL and 3pt are operating properly. The 5 A fuse for the PTO is good. Hydraulic level was down about 1/8th of an inch on the dipstick. Refilled to the proper level. Still nothing. I am looking for suggestions before I call the dealer because it could probably be an operator goof up since I am known to all to do stuff <grin>.
